Boiler bushings
jlakes85
Boiler bushings
Post by jlakes85 »
Hi all,
I'm currently building a buckwalter Shay boiler using an all TIG process. Concerning half couplings used for the various bushings, are the rules for joint gapping the same as for the sheets, i.e. about 0.125 all around or is a narrower gap permissable? Thanks again.
Regards,
Jlakes85
Marty_Knox
Re: Boiler bushings
Post by Marty_Knox »
You'll never locate them accurately with that kind of gap. I'm at home, so I don't have my reference books handy, but Monday I will post the relevant information.
jlakes85
Re: Boiler bushings
Post by jlakes85 »
Hi Marty,
Sounds good, much appreciated. Once I tracked down the appropriate class 3000 couplings from McMaster and crossed referenced to the drawing, I started to scratch my head..1.150 hole for a 1.125 OD bushing e.t.c. Gonna really have to crank the machine up to get that keyhole going..
Marty_Knox
Re: Boiler bushings
The relevant wording is from Section 1 of the ASME code, PW-16.5 Internally threaded fittings less than NPS 3 (3" pipe) may be attached by a fillet groove weld from the outside only.
My scanner isn't working so I can't post the illustration.
jlakes85
Re: Boiler bushings
Post by jlakes85 »
Hi Marty,
Sounds good. Thank you again for digging this up. I'm surprised that the code allows a fillet groove up to that large of a pipe size. It does make life a whole lot easier, as well as my sanity overall in second guessing hole size call outs as compared to the class 3k coupling OD's.
The Feb 89 issue of Live Steam as well as the Oct 87 issue of Modeltec did a good job of drilling into my head the general dangers and prohibition of using fillet welds on a pressure vessel.
Fender
Re: Boiler bushings
Post by Fender »
Marty,
Could you clarify what a "fillet groove" weld is? I looked up images of different weld joints and didn't see that one.
Thanks.
Dan Watson
Chattanooga, TN
Marty_Knox
Re: Boiler bushings
fillet groove weld.pdf
(97.58 KiB) Downloaded 365 times
Fender wrote:Marty,
Thanks.
jlakes85
Re: Boiler bushings
Post by jlakes85 »
Hi marty,
Looks good. Judging by the PDF, I would only need enough of a hole clearance to slip the bushing through
Bastelmike
Re: Boiler bushings
Post by Bastelmike »
Hi Marty,
thank You for the explanations and sketch.
Being from the metric world, I'm a bit surprised about that 1/4" dimension. 1/4" for let's say a 1/2" pipe to a pressure vessel Looks a little oversized to me.
My memories about the German pressure vessel regulations in effect until 2000 that the weldment dimensions were very dependent on the size of the opening (i.e. pipe size). Forces involved are correlated to the opening area so weldment should be stronger with increasing pipe size.
Mike
Marty_Knox
Re: Boiler bushings
That 1/4" dimension is for 3" NPT. The requirement is that the weld thickness be equal to the wall thickness of Schedule 160 pipe. For 1/2" NPT that would be 3/16". Another rule says the welds for less than 3" pipe are exempt from the size requirements as long as there is enough weld to provide the required strength.
The rules were not designed for our size boilers.
Fender
Re: Boiler bushings
Post by Fender »
Interesting that the weld on the left side of the coupling on the drawing is different than the one on the right. Does this mean that either is acceptable?
Dan Watson
Chattanooga, TN
Marty_Knox
Re: Boiler bushings
Yes it does. Things like the angle are 'non-critical variables'.
