Boiler bushings
Boiler bushings
Hi all,
I'm currently building a buckwalter Shay boiler using an all TIG process. Concerning half couplings used for the various bushings, are the rules for joint gapping the same as for the sheets, i.e. about 0.125 all around or is a narrower gap permissable? Thanks again.
Regards,
Jlakes85
Regards,
Jlakes85
Re: Boiler bushings
You'll never locate them accurately with that kind of gap. I'm at home, so I don't have my reference books handy, but Monday I will post the relevant information.
Re: Boiler bushings
Hi Marty,
Sounds good, much appreciated. Once I tracked down the appropriate class 3000 couplings from McMaster and crossed referenced to the drawing, I started to scratch my head..1.150 hole for a 1.125 OD bushing e.t.c. Gonna really have to crank the machine up to get that keyhole going..
Re: Boiler bushings
The relevant wording is from Section 1 of the ASME code, PW-16.5 Internally threaded fittings less than NPS 3 (3" pipe) may be attached by a fillet groove weld from the outside only.
My scanner isn't working so I can't post the illustration.
Re: Boiler bushings
Hi Marty,
Sounds good. Thank you again for digging this up. I'm surprised that the code allows a fillet groove up to that large of a pipe size. It does make life a whole lot easier, as well as my sanity overall in second guessing hole size call outs as compared to the class 3k coupling OD's.
The Feb 89 issue of Live Steam as well as the Oct 87 issue of Modeltec did a good job of drilling into my head the general dangers and prohibition of using fillet welds on a pressure vessel.
Re: Boiler bushings
Marty,
Could you clarify what a "fillet groove" weld is? I looked up images of different weld joints and didn't see that one.
Thanks.
Thanks.
Chattanooga, TN
Chattanooga, TN
Re: Boiler bushings
Fender wrote:Marty,
Thanks.
Re: Boiler bushings
Hi marty,
Looks good. Judging by the PDF, I would only need enough of a hole clearance to slip the bushing through
Re: Boiler bushings
Hi Marty,
thank You for the explanations and sketch.
Being from the metric world, I'm a bit surprised about that 1/4" dimension. 1/4" for let's say a 1/2" pipe to a pressure vessel Looks a little oversized to me.
My memories about the German pressure vessel regulations in effect until 2000 that the weldment dimensions were very dependent on the size of the opening (i.e. pipe size). Forces involved are correlated to the opening area so weldment should be stronger with increasing pipe size.
Mike
Mike
Re: Boiler bushings
That 1/4" dimension is for 3" NPT. The requirement is that the weld thickness be equal to the wall thickness of Schedule 160 pipe. For 1/2" NPT that would be 3/16". Another rule says the welds for less than 3" pipe are exempt from the size requirements as long as there is enough weld to provide the required strength.
The rules were not designed for our size boilers.
Re: Boiler bushings
Interesting that the weld on the left side of the coupling on the drawing is different than the one on the right. Does this mean that either is acceptable?
Chattanooga, TN
Chattanooga, TN
Re: Boiler bushings
Yes it does. Things like the angle are 'non-critical variables'.
