I wouldn't buy it unless it came with 2 spindles. One for O.D. grinding and one long spindle for I.D. grinding. It can be hard to find the missing spindle.
Richard W.
should I buy this grinding attachment?
Re: should I buy this grinding attachment?
The degree of precision is really reliant on the machine----and lathes, particularly old lathes, simply can't provide the level of precision offered by purpose built cylindrical grinders. Even a cutter grinder falls woefully short in that regard. I was once forced to use a cutter grinder for cylindrical work. Sorriest day I ever spent grinding.liveaboard wrote: I had assumed the grinder would improve accuracy. Thanks for setting me straight.
Tight tolerance work with a tool post grinder is accomplished more by luck and skill, thanks to the inability to set taper, reliably feed the wheel, and to control temperature at the grind. That said, because a wheel cuts without tearing, you would experience a degree of higher performance, but you'd still be locked in with the limited precision of lathes. A tool post grinder is a poor substitute for a cylindrical grinder, but it is better than no grinder.
- liveaboard
420 GBP is way beyond my budget for inessentials I'm afraid; my machine shop spins on a shoestring.
Anyway, I've given up on the one advertised. As you all pointed out, it's just not the right tool.
"Always use the right tool for the job." an old machinist told me, as he used the edge of a piece of broken glass as a hammer for extracting a broken off machine screw.
