The horizontal spindle hasn't been used in years, so I'm thinking it might be a good idea to drain and flush out the spindle oil reservoir, and also the back-gear box. If possible, I'd like to do it without disassembling everything. I would like to hear from anyone who has tried this, and whether or not you were successful.
Thanks,
John
Bought a Rockwell 21-120 Mill
Re: Bought a Rockwell 21-120 Mill
The gearbox and the spindle bearings are two different things. The information that I have, says that the gear box is filled with 7 FL. oz of EP-140 gear grease. The spindle roller bearings use CAT # 24-812 spindle oil ( having a viscosity of 58-60 SAYBOLT at 100* F ). The bearings have outside oil
seals to prevent the grease. In oiling the spindle, there is a breather screw which must be removed and THAT is very important for it to be flushed.
From what I read, the spindle is oiled near the bottom of the casting and that can't happen unless there is a breather atop. There is some sight glass for the level. This is from PM-450-02-651-0001 dated IM-7-15-68 .
I discovered that the back gear box has a drain plug. That will make draining & flushing the it a lot easier; no worries there.
The spindle reservoir is a different story. The only usable access is via the filler hole. There is a breather hole as spro suggests, but it's small, about the size of a 10-32 machine screw. The screw is missing. That might explain why the oil is so dark, almost black. Definitely needs to be drained & replaced!
It is a great machine. Rockwell engineering knew what they were doing in those times. Everything was balanced together.
Then again, some weren't.
Can someone who owns one of these mills please explain how to lube the bevel gears that are inside the knee? I followed the instructions in the manual I have, but when I pull back the shield to expose the hole, all I can see is the cross slide feed screw. What am I doing wrong?
Crank the saddle all the way to the front stop, which drags both cover plates to the front. Reverse and crank the saddle to the rear, dragging the top cover plate, and stop when the second cover plate starts to move (about half way back). Push the top cover plate to the rear (under the saddle) with your fingers to expose the hole. If you need to, you can then crank the saddle back another 1/4~1/2" and push the top cover plate again to get a little bit more opening.
You can do the same in reverse to expose the hole from the rear. In both case, you can clearly see the crossfeed screw, but the beveled gear is very difficult to see. Probably best is from the front right corner, get down low and peer in, you can just see it under the screw. I just squirt some way oil on the screw and run the table back and forth a few times, it dribbles off the saddle nut and down onto the bevel gears.
Choprboy, thanks for the pictures and description! By exposing the hole to the rear, and using a small flashlight, I was able to access the gears well enough to see and oil them. They looked like they hadn't seen oil in quite some time.
John
John
It really depends on the load on the motor during horizontal milling operations. The smaller VFD will work but will trip when load exceeds it's capacity. I'm sure this is also highly dependent on the numerous VFD settings / parameters.spro wrote:As you suspected, running the 1 1/2 hp under load, may be too much.
