Using Alt-Character Test
Get community help here, post test messages, suggestions etc. I will also document here changes that take place such as maintenance and upgrades.
Moderators: Harold_V, Marty_Escarcega
warmstrong1955
Re: Using Alt-Character Test
Post by warmstrong1955 »
Now to find π on the iPad.....
Steggy
Post by Steggy »
mklotz wrote:
BigDumbDinosaur wrote:How about Ø θ — – µ π – § ¿ ! © ® ™ ° ± ¶ † ¹ ² ³ ¼ ½ ¾ × ÷ • → € ♫ ♮ ♭ ♯?
Most anything listed as an HTML entity ought to work.
What Alt-code did you use to get the image of pi? I can't seem to find that in my list of the codes. TIA.
Hold down the Alt key and while doing so, type the numerals 2 2 7 in succession on the numeric keypad. Release Alt and a π symbol will appear. For the typographically meticulous types, the glyph is not exactly correct, but close enough for government work. :D
Incidentally, this works for a number of other symbols: ☺ ☻ ♥
Those came from Alt-1. Alt-2 and Alt-3, respectively.
Research is what I'm doing when I don't know what I'm doing.
mklotz
Post by mklotz »
I normally compose posts in my editor (DocPad) and, while some of the Alt codes work there, the pi symbol doesn't; it produces the lower case 'p'. However, if I edit the post using the forum software, it works as advertised and produces the pi letter.
This is true for a few of the other symbols mentioned on the page that Bill mentioned. I can only conclude that my editor only makes available the codes embedded in the Windows font.
Regardless, thanks for your help.
Regards, Marv
Home Shop Freeware
warmstrong1955
I think that's it Marv.....works on anything Windows. I tried it in Outlook, Word, & Excel....got a π in all.
I'm not familiar with DocPad.
Bill
ctwo
Post by ctwo »
I was going to suggest it may be a font limitation, but then I remember something about the original ASCII standard character set is only 7 bits (mostly covered by your keyboard). I've entered in all of the extended 8-bit ASCII codes into Excel and used the CHAR (and alternatively CODE) function to see what characters are produced. They all do not work there either. Furthermore, if I copy π from here and paste it into Excel (or manually key in the ASCII code), I get π. But decoding that gives me ASCII 63, which is a ?
mklotz
Post by mklotz »
Copying and pasting seems to work in DocPad as well.
Regards, Marv
Home Shop Freeware
warmstrong1955
It works on my old XP laptop, with excel 2003. No number pad, but there's a num lock button. And I had to hold down the Fn and alt keys....and the numbers 1 thru 6 are hi-lited in blue below some letters on the upper righ, instead of across the top.
Confusing....but it works.
Bill
