CPR G5C Class 1246 Pacific
Berkman
Re: CPR G5C Class 1246 Pacific
Post by Berkman »
That seems like a nightmare building a cylinder block that way. Save yourself a year of design/build work and years of frustration with getting it to seal and buy a cylinder block from Little Engines. Would be worth every penny...
thunderskunk
Post by thunderskunk »
Berkman wrote:That seems like a nightmare building a cylinder block that way. Save yourself a year of design/build work and years of frustration with getting it to seal and buy a cylinder block from Little Engines. Would be worth every penny...
You're right. I backtracked a little bit, and I did take a second look into the little engine's castings as well. I could probably make their light northern parts work, but the price isn't right. I think I've got what I need in the scrap pile anyways. I tried copying a welded cylinder block design I saw in Nelson's book there, shown in the attached photo. I'm not an amazing welder, but this seems achievable with a lot of modification to what's shown here. Worst case, I get practice welding and save up for the castings anyways.
I know CAD isn't the favorite method for drafting around these parts, but that's what they teach now. As an aside, it's actually pretty messed up how little they teach about dimensions and tolerancing in school. My boss lent me ASME Y14.5M, which we should have had in class from day one. On the bright side, that CAD stuff is pretty nifty. I found out through parts not matching that the erection drawing I have has a 1/2" vertical offset between the cylinder and driver center lines, and that the positions shown are not exactly halfway between TDC and BDC. Those two errors alone would have added up to 3/4 inch of rod length where I wouldn't want rod length.
thunderskunk
Hey,
Just a quick update. I think I've got the majority of the linkages figured out. I have a lot of playing to do with the saddle and cylinder block in general, but I've seen a welded-up cylinder set before so I think it'll work. Once I have the channels drawn up for steam passages I can verify the linkages are all in the right spots, then I'll feel comfortable cutting up the frame. Worst case, I cut everything but the saddle mount
Some calculations from Machinery's Handbooks says my little press idea for wheels is impossible for what I want to do. Lots of silly number crunching, and it was a whole lot of fun, learned a lot, but a waste of time otherwise. Just picked up a rotary table from work, so I can do my own patterns no problem.
All said and done, the boiler barrel shown is a draft, and by the looks of it.... yea I'm thinkin about faking the 9 inch section as well. DOM tube is way too expensive so I can get a tiny bit more steam head. Lots to think about, but a few years out anyways. Took me a bit, but I found out the right side leads. I just spotted that nifty little bolt-in counterweight on the middle driver (anybody know what that's called?) which meant the 90 degree offset had to go in one specific direction.
Mountaineer
Post by Mountaineer »
Carr's Machining in Vancouver BC has a cast iron cylinder block for CPR locos. Only slightly larger than scale for a G5 but would suggest using someone's casting and not going down the route of fabricating. Esp as a beginner.
Mountaineer.
"Took me a bit, but I found out the right side leads."
Most locomotive builders had the right side cylinder lead.
However, the Pennsylvania RR designs had left hand lead! (?All of them?)
I bet Charles Wooten, one of their major early designers, was left handed...
makinsmoke
Post by makinsmoke »
And they ran their geeps backwards.....
:lol:
thunderskunk
makinsmoke wrote:And they ran their geeps backwards.....
:lol:
I did the inspection on a GP9 replacing check valves and control stand parts (1272 day? it's been a while) where they'd manufactured the engine to go backwards because of one union's demands, then was sold to another railroad where the requirement was the opposite, so it was a backwards-facing cab refitted to face forward. That was a mess...
Pontiacguy1
Post by Pontiacguy1 »
The Southern also ran their Geeps long-nose to the front. They said it was to protect their crew in case of a crash.
thunderskunk
Last CAD update, I swear.
My 'assembly' of the linkages is finish, which means I now have a moving projection. Like, it moves. I'm pretty happy with it.
I have lots of number crunching to do now. My slots in the valve liner are in the wrong spots, and something is causing the reverser in center to still admit steam into the cylinders. I might do the spring rigging as well, but I have those drawings and they're pretty straight forward.
Might make a model of one side in 3/4" scale to play with the possibility of fabricating the cylinder block. If I find that impossible, I'll go the route of finding a casting, I promise.
thunderskunk
I'm still here I swear! I check back in every so often to see who's doing what.
I would say almost to the day that I'd finally situated my shop exactly how I wanted it for this project, life got turned upside down. I went from being a CNC machinist in Vermont to being an engineer for a company making turbine parts in Connecticut within a month. Now my tools are scattered between four locations, and it took me a month to get the garage situated so I could function. After moving my lathe down here, I found a 3 in 1 to supplement the bridgeport back at home so I can plug away at small stuff. It is... in terrible shape. I'm sure it wasn't a great design to start with, but it's a project to be sure. I think the guy who had it has been milling with his drill chuck for as long as he's had it, so fat chance I'll be getting collets in there. Doesn't help that the draw bar has a custom key that the fella who sold it didn't have on him.
This will work out though. I have a lot of tools to repair; plasma cutter air regulator blew a few weeks ago, TIG welder needs some tuning, lathe needs the switch contacts cleaned, the 3-1 needs to be almost entirely rebuilt (but I probably will not), etc. The A36 is sitting there waiting for the plasma cutter to function, and we'll be on our way.
Another weird process I might have access to: Sinker EDM. I guess I'm the subject matter expert on the process until another engineer gets back in a year, and it's pretty cool. I might get to mess around with a bit of scrap graphite and a machine for some little stuff. It's really not suited for most parts, but it might help in my cylinder fabrication for cutting ports. Might try detailing the smoke-box door with it, bolt heads and such.
thunderskunk
thunderskunk wrote: Wed Sep 20, 2017 8:48 pm
[*]How often, if ever, do live steam modelers use forgings instead of castings? I've got a set up for propane blacksmithing and a plazma cutter, so most of what I do will be dictated by what I can make stock look like using those tools.[/list]
Alright... It's been 5 years or so.
I found this video of wheel forging:https://www.youtube.com/watch?v=f5glBHADoug&t=172s
I've learned a lot since I thought forging a wheel casting was a good idea. I work at a place that actively uses drop hammers for the last few parts we can't machine economically. Yea... not forging wheels.
I'm taking delivery of a monster of a CNC machine: A tsugami TMA8. It's old, but it could machine just about every part on a live steam engine in a few days without a heck of a lot of setup to include spoked wheels. I've been trying to "pick up where I left off" with this project a few times a year, only to have something get in the way; we're about to pop out kid #3, the Army keeps deciding to send me places, and I keep chasing machine shop customers that turn into dead ends.
It's been... "fun"...
