Project: N&W class J on 5"gauge
Steamchris
Re: Project: N&W class J on 5"gauge
Post by Steamchris »
back again...
Jack for piston valve
Back of Cylinder with Holder for Slideways - Crossheads
mounted piston valve
All the Best and kind Regards
Chris
Health and Safety Notice
has been switched off !
WJH
Post by WJH »
Chris, where in Germany are you? I frequently go to Leipzig for work as I do flying for DHL, would love to see your work up close. Also, I know you’ve mentioned it before, the way you mount the drivers to the axles, what’s that called?
Steamchris
Hello WJH,
your are searching for taper loc's or taper jacks. You can buy it here....
www.maedler.de/product/1643/spannsaetze ... perbuchsen
I live near Düsseldorf, round about 5 hours by car away from Leipzig,you are welcome.
All the best
Chris
alco2350
Post by alco2350 »
Those cylinders are beautiful!
Britt
Sent from my Galaxy Note 8 using Tapatalk
Steamchris
Hi Guys,
some news on our J,we finished the slide ways and were able to put it on the Cylinder, everthing fits well.
The crosshead is just a Dummy to show the dimensions of the parts...dont forget its just 5"Gauge.
I cant wait to be in front of the prototyp. Just 68 Days...
Regards
Chris
Steamchris
Hello Guys,
time to post some progress on #611.
The last post showed the Slideways with the Dummy Crosshead made of Aluminium.
During the last Days the right Crossheads grown more and more. The Body is made of SS Steel the Shoes are made of Bronze.
47 Days to go,then we will enter your beautiful country for the first time.
All the very Best
Chris
PeterCraymer
Post by PeterCraymer »
Beautiful Work!
Steamchris
Hello Peter,
thank you.
All the best
Chris
Steamchris
Hi Guys,
some Detail work on the Alligator Crossheads....
All the Best,
Chris
Asteamhead
Post by Asteamhead »
Hello Steamchris,
Some important progress with your J, congratulation! The day of it's initial first run on air is in sight now, isn't it.
For better understanding the construction of that Timken crosshead for both the A and the J, there are some more photos.
Maybe some other modelers are interested in that careful and proven construction of that Timken crosshead with (clamped) ball bearings?
Both easy to mount and disassamble without any backlash. Grease my be pressed between the bearings by means of a small chanal once a year.
Asteamhead
Clamping of the piston rod's end is very rugged! The short thread at the inner end is intended to help  adjust the position of the rod
The small end with it's pair of ball bearings will be clamped by means of tapered shaft and splited ring
The tapered splited ring is to be seen. Shaft, inner rings of the bearings and crosshead halfs will be clamped by the cover plate
The final safety spring is still missing, sorry!
Steamchris
Hey Asteamhead and others,
WD,thank you for your words and for the extansion on my Report.
Today it was able to use the Press during my Breakfast-break. So the Bolts are right now on the right position.
I started first with the Crankpin....i think the pictures will tell more.....
All the best
Chris
Satisfying progress.
