Threading without the end groove
Re: Threading without the end groove
I'm making reference to the side near the chuck, which, when held according to the method used to hand a cutter, is the right side. I probably should have made that clear.
Post by Bill Shields »
Giggle....you have never programmed a LEFT HANDED Swiss type machine with the collet on the opposite side..
Dave_C
Post by Dave_C »
Thanks for posting the explanation so the newer members aren't confused. The tool hand thing is a bit confusing at first.
Dave C.
GlennW
Post by GlennW »
Dave_C
Post by Dave_C »
Nice!
pete
Post by pete »
Dave, easiest way to remember the "hand" a lathe tool is would be to hold both your hands out in front of you with your thumbs pointing towards each other. The direction the thumb is pointed equals what the lathe tool does. Example right hand tool or moving from the tailstock end to the headstock end. Left hand just the opposite. Exactly why tools are termed opposite of what logic says they should be I've never read a good explanation for. Years ago one member on the HSM forum went so far as saying all the books and anyone who used what the books said for the correct tool hand were completely wrong and he refused to use what he knew were the wrong terms. :-)
GlennW
Post by GlennW »
I just remember that it is the opposite of what you think it is.
Dave_C
Post by Dave_C »
I actually remember it by looking at the way it approaches the part to make the cut. From the right is a right handed tool. (even though you are moving left to make the cut) I wasn't asking about how to hand a tool, I was asking for clarity so other readers would not be confused. Harold did a great job of clearing up the post and you all did a great job of adding detail and pictures.
It's all good!
Dave C.
drmico60
Post by drmico60 »
I made an electrical autostop for my minilathe, see:
http://mikesworkshop.weebly.com/autostop.html
This auto stop was origianally designed to stop the carriage whilst it was being driven by a small DC motor.
At a later date I modified the control circuit so that it would turn off the main lathe motor. This is ideal for screw cutting because the lathe will automatically stop when the carriage reaches a certain point. Thsi later modification is described here:
http://mikesworkshop.weebly.com/lathe-m ... ntrol.html
As a further refinement I made a swing up threading tool, see:
http://mikesworkshop.weebly.com/swing-u ... older.html
This combination of lathe motor autostop with a swing up toolholder making screw cutting without a runout groove very simple.
Mike
John Hasler
Post by John Hasler »
Very nice. A comment, however: it is better not to use snap-action switches where you need precise repeatibility. They seem nice and crisp but they are actually not as repeatible as simple contacts.
I like the swinging toolholder idea.
drmico60
Post by drmico60 »
John Hasler wrote: Sun Mar 25, 2018 11:46 am Very nice. A comment, however: it is better not to use snap-action switches where you need precise repeatibility. They seem nice and crisp but they are actually not as repeatible as simple contacts.
Using the microswitches I get about 0.1 mm repeatability which seems to be good enough for threading. I do like the idea of a simple contact switch and when I have time I may make some experiments to see how the two types perform for repeatability.
Mike
joelallan
Post by joelallan »
1. Turn the threading tool upside down and level accordingly.
2. Use an indicator on the ways to set a zero reference on the carriage where the threads are supposed to "end".
3. Run the chuck in reverse from where the threads are to end.
4. Engage the half nut and advance the cutter in .001-.002" to confirm you set up the gearbox correctly for the ptich. After that never disengage the half nut until the threads are done. Move the tool out after the first cut and then rotate the chuck forwards to bring the carriage back to the zero location. If you overshoot it then move the chuck in reverse until you get back to your zero location.
5. When you are ready to turn the chuck on again in reverse advance the crossfeed in .010-.015" and repeat at the moment you turn the chuck on. Thread cutting depth is dependent on the size and rigidity of your lathe. If you get a lot of chatter back off to .005-.010".
6. When you get towards then end of the entire process make your advanvces .001" and finally no cuts at all but running ove the same threads several times. Use lots of oil.
7. Remember the process (regardless of cutting upsidedown and reverse or traditional) will create a burr on the crest of the threads so be sure to file them down inbetween checking your fit otherwise you will make your threads undersize just trying to get your nut on. A MIC is better than calipers for checking the diameter.
It is time consuming but the threads will actually be stronger than if you have a relief groove. This is the same method to make metric threads with a standard QC gearbox with a metric capability. Never disengage the half nut until the threads are perfect. I do it all the time. If done right you can even make multiple pitch threads by moving the compound, obviously for courser pitch regardless of left hand or right hand.
