Gem DTI
Mr Ron
Gem DTI
Post by Mr Ron »
I have a Gem DTI, model 222, an old one for sure. I need to use it now to assist my installation of my new DRO. The DTI is working erratically. The needle won't return to zero consistently in one direction, but it does in the other direction. I put a drop of light oil in the mechanism, but it didn't do any good; any thoughts?
Mr.Ron from South Mississippi
John Hasler
Re: Gem DTI
Post by John Hasler »
I have one of the those. Rinse all the oil out (I use starting fluid) and oil only the bearing where the probe pivots. Make sure the needle isn't dragging.
Mr Ron
Re: Gem DTI
Post by Mr Ron »
John Hasler wrote: Wed Jul 11, 2018 3:11 pm I have one of the those. Rinse all the oil out (I use starting fluid) and oil only the bearing where the probe pivots. Make sure the needle isn't dragging.
I'll give that a try. According to Long Island instrument repair, the Gem is not considered a good DTI and not worth repairing. They call it a poor copy of the Starrett "Last word" DTI's. I got it for free, so I'm not to concerned if it doesn't work as it should.
John Hasler
Re: Gem DTI
I've got one of each. I don't see any significant difference.
Re: Gem DTI
John Hasler wrote: Thu Jul 12, 2018 4:41 pm I've got one of each. I don't see any significant difference.
If that's the case, my opinion of the Gem is not good. I've owned a Last Word since 1958. It was returned to Starrett for repair when it was not reliable, but it quickly returned to that same condition. The only real use it has now is in removing taper from a grinder, and it seems to deal with that adequately. There is no doubt in my mind, they are not a good indicator (keeping in mind, the vast majority of my instruments are Starrett).
The user has no idea they aren't working, as they behave as if they are, but when a more sensitive indicator is used in conjunction, the difference is obvious. Mine remained motionless when, in reality, I had something like a half thou movement. Doesn't sound like much, but the job I was running had only .0002" tolerance, so I was woefully out of tolerance when it indicated zero movement.
This topic has been discussed endlessly (without rancor). It is generally accepted that there are far better indicators on the market. My choice is the B&S BesTest, of which I own three. I have owned one of them in excess of 50 years. It already requires a replacement of the crystal, and has, otherwise, served me perfectly well without any issues. You just can't buy good things these days. :D
