I found this on Shapeways
This is a highly-accurate railroad AB valve rendered in 1/8 scale for live steam modeling use. This part is designed to be attached to a model railroad car using long bolts or pins supplied by the modeler, just like the real valves are mounted. All pipe ports are included and are scaled to prototypical standards. The air filter comes attached to the valve.
https://www.shapeways.com/product/BVGT4 ... -inventory
Tim
1-1/2" Scale AB Valve
