kozo a3 5/32 and 1/8 tube wall thickness
sky
Post by sky »
Hi,
Need some help on sourcing tubing for Kozo A3 Switcher. Looking for the 5/32 and 1/8 tube with thick enough wall for the water piping on the Engine. I think it is about .025 to .031 wall thickness. Have boiler all solder up. Looking to do pressure test. Need a pressure gauge for the test, and one for the engine 1" in diameter. A source for both would be very helpful.
Thank you.
sky
gwrdriver
Re: kozo a3 5/32 and 1/8 tube wall thickness
Post by gwrdriver »
Refrigeration capillary tube.
GWRdriver
Nashville TN
sky
Post by sky »
Thank you.
any chance of finding a 1" pressure gauge for the engine in the USA without spending and arm and a leg?
sky
Builder01
Post by Builder01 »
American Model Engineering Supply has beautiful gauges at 1-1/4" in diameter. They are not cheap, but, you get what you pay for. Less expensive gauges are available from England. Otherwise, you can cheap out and get the smallest gauge from the hardware store, but, it will not be 1".
David
Wayne Davis
Post by Wayne Davis »
PM Research has a 7/8" gauge for $16.00.
https://www.pmmodelengines.com/shop/ste ... ure-gauge/
Wayne
sky
Post by sky »
American Model Engineering Supply was bought out by Godshall's custom machining. There website is outdated, I sent them a message, waiting to hear. PM Research has range of 0-100 on there gauge. Not to fond of the cheap one. Looking for a range of 0-150 psi as the A3 max. running is 100 psi.
sky
sky
Post by sky »
No answer back from Godshall's
Soot n' Cinders
Post by Soot n' Cinders »
I dont know about their email, but they always answer the phone number on the website
-Tristan
Projects
10 Wheeler Rob
Post by 10 Wheeler Rob »
You can get 1 1/2. Test gage in several pressure ranges from McMaster Carr for around $15 plus shipping.
sky
Post by sky »
got the test gauge. Looking for 1" dia for the engine. I will try calling the phone number later in the week.
Thank you for the information. All is greatly appreciated.
sky
