Need coupling bored and key way broached
I'm trying to swap a motor on my log splitter but I found that the new motor shaft is 1"and the old was 3/4" so the coupler to the pump won't fit. I've tried to find a new couple without success. The problem is that the key way is 3/16" and I am not coming up with that size in a 1" bore. The coupling I have is a Lovejoy L075. I have a Grizzly 3 in 1 but it's brand new and not ready to run. Can someone in the area of Granite Falls, WA do this?
- BigDumbDinosaur
Re: Need coupling bored and key way broached
Rather than go through that much trouble, why not replace the coupling with an L95 or L100, using a combination of a 3/4 inch bore half and a 1 inch bore half? For example, two pieces of McMaster SKU 6408K14 (one piece with 1 inch bore and the other with 3/4 inch bore) and one piece of McMaster SKU 6408K75, which is the "spider." The smaller bore would be attached to the pump shaft.4elements wrote: ↑Tue Jun 04, 2019 2:41 pmI'm trying to swap a motor on my log splitter but I found that the new motor shaft is 1"and the old was 3/4" so the coupler to the pump won't fit. I've tried to find a new couple without success. The problem is that the key way is 3/16" and I am not coming up with that size in a 1" bore. The coupling I have is a Lovejoy L075. I have a Grizzly 3 in 1 but it's brand new and not ready to run. Can someone in the area of Granite Falls, WA do this?
I'm a caterwauling curmudgeon. What's your excuse? ☻
Thanks for the reply. When I searched both lovejoy and McMaster I didn't find a coupling with a1" bore and a3/16"keyway in the L095 series. Also my pump shaft is 3/8".I may have missed something, but I couldn't come up with a working combo
Use a stepped key.
Greg
Greg
- BigDumbDinosaur
A 3/16 inch keyseat is not industry-standard for a 1 inch shaft. Are you sure about the PTO shaft on the engine?
Yes it's 3/16". That surprised me too when I researched it. The motor is a Briggs&Stratton from a front wheel drive lawn mower that the drive gear box failed on. I found a co- worker who will do it for me.
Take the 1" coupling and have a 3/16 keyway cut, a 10 minute job. As long as its not a blind hole, if a 2 piece coupling is what I assume it is.
Sent it to me the keyway is gratis, you pay shipping.
My wheels don't slow me down
