welding a shaft
mikechoochoo
welding a shaft
Post by mikechoochoo »
I want to weld a piece onto the the screw from a vise, it's about 3/4 inch diameter. The weld will be two inches from the threaded portion and will be replacing a old botched repair done by a previous owner. I plan on making the new part slightly larger than the final diameter and turning it to size after the welding is done to account for warpage. The question is should I weld a scarf joint or a but joint that is v'ed with the parts center drilled with a pin to hold their alignment . Yes I could turn a whole new screw but it's a buttress thread and I feel welding is the easier course.
Mike N.
Russ Hanscom
Re: welding a shaft
Post by Russ Hanscom »
My personal preference is to make a V joint. I use a piece of angle iron to maintain alignment; clamp the pieces into it. Shim one side if the diameters are different. Make a pass, flip and make a pass, repeat as necessary. Should be able to keep it relatively straight.
Helps to put a rib on the back of the angle for clamping it in a vise and also helps to cut away of bit of the angle sides near the welding area for better access.
LIALLEGHENY
Re: welding a shaft
Post by LIALLEGHENY »
I agree with Russ, make a V-joint.
Nyle
Russ Hanscom
Re: welding a shaft
This is my basic fixture. Make one suitable to your needs.
johnfreese
Re: welding a shaft
Post by johnfreese »
Make the extension considerably oversized and the need for accurate alignment goes away. Definitely use a V groove.
