Bandsaw downfeed control
whateg0
Post by whateg0 »
My 7x12 Shop Fox has the typical hydraulic downfeed control found on these saws. I bought it a few months ago and only used it for the first time a couple nights ago. From what I can see, the needle valve is inline with the ball valve, and there is no way to speed the downfeed when bringing the blade closer to the work except to open the needle valve all the way, and the readjust it for the cut. Are there other models of saw that have a bypass for that? A friend of mine says I'm just too impatient, but especially when using a coarse blade on thin stock, it can be a real pain to get it tuned so it doesn't grab, so I'd prefer to not have to do it each time.
Dave
pete
Re: Bandsaw downfeed control
Post by pete »
You could swap the needle valve for a small lever operated ball valve.
SteveM
Post by SteveM »
pete wrote: Wed Aug 14, 2019 2:14 pm You could swap the needle valve for a small lever operated ball valve.
I think a ball valve might open too large too quick to be a replacement for a needle valve, but it's probably worth trying.
I got a Horror Freight one that a friend gave me (yes, he's still a friend).
Since I got it , I found that there are HOURS and HOURS of videos on how to improve them.
John Hasler
Post by John Hasler »
Add a ball valve in parallel with the needle valve.
SteveM
Post by SteveM »
John Hasler wrote: Wed Aug 14, 2019 2:49 pm Add a ball valve in parallel with the needle valve.
I like that. It's either open or needle valve.
Post by Glenn Brooks »
I have the same problem with an old Grizzly 7x12 bandsaw I recently purchased - and had to rebuild. Very disappointing, as the smallest miss adjustment of the little hydraulic cylinder will jam the work and pop the blade off the wheels.
I have found the vertical position on my valve allows me to raise and lower the saw by hand. Then If I manage to reset the valve to the “correct” 30* angle each time, all is good. So basically have found two good positions for the valve - ‘up/reset’ and ‘down’.
I should try to put a stop in place to quickly find the magical valve setting to cut. But, don’t use the saw daily - only randomly a few times a year for many short cuts whilst starting some odd project, so not worth the time to properly fix this miserable design error.
rudd
Post by rudd »
Huh, my 1930's Excelsior power hack doesn't have those issues. And it's fun to watch! :)
whateg0
Post by whateg0 »
That's what I was comtemplating. Looks like a bit of work to plumb it in, but I really think it's probably worthwhile.
If I wanted to go that route, I would just open up the needle valve all the way and just use the existing ball valve. The whole purpose of the needle valve is to provide fine control of the fluid flow. A ball valve negates that.
Dave
whateg0
Post by whateg0 »
rudd wrote: Thu Aug 15, 2019 8:03 pm Huh, my 1930's Excelsior power hack doesn't have those issues. And it's fun to watch! :)
I have an old power hacksaw. Don't recall if I ever figured out who made it, though. Someday, I want to get it unfrozen and see it work.
Dave
spro
Post by spro »
Well cool but John H. already had it. Constructing a minor manifold could be fun using fittings appropriate, yet no real call for them in foreseeable future. Probably a support strut because operating the ball valve would loosen the thread seals over time. Slick concept.
whateg0
Post by whateg0 »
spro wrote: Fri Aug 16, 2019 12:06 pm...operating the ball valve would loosen the thread seals over time. Slick concept.
Huh?
Second that "Huh?"
RN
