pneumatic bell ringer
- LivingLegend
Re: pneumatic bell ringer
Outside mount or inside the bell?
Do it right.... Or don't do it at all
I have no life. Therefore, I have a hobby
It's not that I'm apathetic, I just flat don't care
An Intellectual is nothing more than an Over-Educated IDIOT
Blogs: Where people with nothing to say..... Say it
Like these?
I have never seen a clapper ringer in small scale...but here is UP's idea of how they are made.
i also have a set of SLDDRW files that I made a long time ago for the external ringer that it seems I cannot attach here...so...
if there is interest, let me know and I will send them to whoever. bshields at mehrs dot com
one important item to note...the bell must be balanced such that the weight of the bell assembly will cause the unit to return..otherwise it will not operate correctly. Joe T. can provide more details on this...but once you think about it...makes perfect sense.
You can try making one that I designed and published on my web site. It is a finicky bugger to say the least. It has to be perfectly balanced. Mine has been working flawlessly after spending countless hours fine tuning it. There are only a few parts but it's simplicity is deceiving. If you want to give it a try, here are the plans/drawings.
http://www.danslocoworks.com/Bell%20Rin ... _(air).htm
Been playing around with Fusion 360 and made this animation of the bell ringer.
https://youtu.be/34qY4hfCLQ8
Dan
http://www.danslocoworks.com/index.htm
Dan
A little history, for anyone interested. In the mid-1950s the Kemtron Corp, Fresno CA, mostly known for their high quality lost wax detail castings used on imported brass O & HO-gauge locomotives, produced a Baldwin bell in 1-1/2" scale as a commemorative piece. They ran it as a curiosity in one of their monthly Model Railroader Magazine ads and it caused a sensation. There was nothing even remotely of its quality on the then live steam market and it was added to their catalogue.
The ringer was a faithful reproduction but was a dummy, although in time Bill van Brocklin devised a working conversion for it. I have a faded copy of Bill's sketches somewhere but can't fins them at the moment.
It was listed in Kemtron's 6th Edition catalogue (probably early 1960s) as a kit #X1115 for the outrageous price of $17.50. This is very similar the early RRS bell, and I heard it claimed it's the same bell, but the details are different and I've often wondered if the Kemtron masters for this survive.
GWRdriver
Nashville TN
Nashville TN
- Greg_Lewis
That foundry is still in business, now known as Valley Brass and Bronze, in the Pinedale neighborhood of north Fresno. While I don't know about the bell, they do lots of work for the indoor RR companies and a few of our suppliers. The owner is a master modeler as well with an interest in WWI and II equipment. If anyone is interested, a Google search should turn up their contact info.gwrdriver wrote: ↑Fri Nov 22, 2019 4:18 pm A little history, for anyone interested. In the mid-1950s the Kemtron Corp, Fresno CA, mostly known for their high quality lost wax detail castings used on imported brass O & HO-gauge locomotives, produced a Baldwin bell in 1-1/2" scale as a commemorative piece. They ran it as a curiosity in one of their monthly Model Railroader Magazine ads and it caused a sensation. There was nothing even remotely of its quality on the then live steam market and it was added to their catalogue.
Greg Lewis, Prop.
Dan, your design is what got this started. I had sold my ride in cab engine to a guy in Cleveland. He turned it to a Porter style and added a large bell and sent me your drawing. I'm looking for a simpler way to do it. My mentor had made a bell rotator like GWdriver showed so I'm leaning in that direction if I take on this project.
Fred V
Fred V
Dan_M wrote: ↑Wed Nov 20, 2019 9:29 am You can try making one that I designed and published on my web site. It is a finicky bugger to say the least. It has to be perfectly balanced. Mine has been working flawlessly after spending countless hours fine tuning it. There are only a few parts but it's simplicity is deceiving. If you want to give it a try, here are the plans/drawings.
Dan
Fred V
Pensacola, Fl.
Pensacola, Fl.
A little more info on bell ringers here.
http://ibls.org/mediawiki/index.php?title=Bell_ringer
http://ibls.org/mediawiki/index.php?tit ... orporation
Regards,
Daris
Regards,
Daris
I'm assuming the bell, just like whistles in this hobby, would have to be made deliberately "out of scale" in order to sound convincing. An oversized "good-sounding" bell should be more than able to accommodate an internal clapper-type ringer. Is my assumption correct?
Physics does not scale down, so yes, a smaller bell will generally have a higher pitch. However, you can make the pitch lower by reducing the bell's wall thickness, which will also make it not as loud.Smokey N Steamer wrote: ↑Tue Nov 26, 2019 1:44 pm I'm assuming the bell, just like whistles in this hobby, would have to be made deliberately "out of scale" in order to sound convincing. An oversized "good-sounding" bell should be more than able to accommodate an internal clapper-type ringer. Is my assumption correct?
Dan Watson
Chattanooga, TN
Chattanooga, TN
