Drill Bit Storage for a Hoarder
My drill bit storage is pathetic. I have an old US Army tool box tray that all my loose bits go into, along with various, (partially-filled) flip containers of various size. Most of the metal flip boxes come from garage/estate sales that were too cheap to pass-up but just add to my collection. And I never trust the ones that have a large number of smaller bits to be in the correct hole.
I've seen some nice storage ideas from the wood working guys but most have one bit for each size. I may have (20) of one size, (10) of another, or maybe none of the size I need at any given time. (I probably have it....I just give up looking). Also, my eye sight isn't what it use to be so the digital calipers are usually in use.
I would like to see how you all store your twist drill bits.
thanks,
dg
thanks,
dg
- seal killer
Re: Drill Bit Storage for a Hoarder
dg--
We all face(d) that problem. I solved it by buying a metal drill bit storage cabinet. I can't remember what it cost, but it was not expensive. It has drawers labeled from teeny-tiny (pro term) to 1/2" in 1/64 or 1/32 increments. (It's not in front of me and I don't remember.)
I also keep (kept - it's all stored for moving) the shop at fairly low humidity levels by running a large room dehumidifier. ($250 or so and WELL worth it.)
Hope this helps.
--Bill
Hope this helps.
--Bill
You are what you write.
Not typically very cheap, but I use the large Huot boxes for bulk storage.
- liveaboard
I have a large drawer only for drill bits; there are several boxes in there of varying usefulness.
Long ago I bought a case of bits at auction; the bits were terrible but plentiful. The case is great, because it allows organised storage for many drill bits, 1 to 10 mm 0.5mm divisions
I'll post a picture tomorrow if I remember.
If I remember! hahahahahahahaha!
I have nine of these:
They are made by Huot.
I have them for fractional, letter and number drills as well as taps, reamers and end mills.
I just picked up a metric master dispenser cheap at an auction and I'm going to change it to hold imperial sizes (requires adding a divider and different compartments in one drawer):
That one will hold fractional, letter and number drills and have the bottom drawer empty, and I will put my drill index cases in that drawer.
- seal killer
Wow, I'm jealous. I only have the primary imperial boxes. I really want that big one at the bottom!
- neanderman
Yeow! I have between two and three sets, with odd 'supplemental' bits; this is truly humbling!
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
Hah, I am with neanderman. 2 full sets, a small handful of duplicates and a large handful of taper shank bigger drills. Oh and a HF set that still has the retaining pin in the case.
I wouldn't have room in the garage for 9 cabinets, much less be able to populate them.
--earlgo
--earlgo
If you put eight of them arranged in a square with the side of one next to the back of the adjacent one, you could put them on a lazy susan and they would take up a space about 20" square.
That's my plan, although I will change a bit with the new one.
I have a bunch of stub drills, so I might repurpose the drill boxes for stub drills.
You could just send me the new box, then you wouldn't have to change anything. Just here to help...
- warmstrong1955
What a generous offer!
