Your favorite low investment/high payoff tools and gadgets
- warmstrong1955
Re: Your favorite low investment/high payoff tools and gadgets
I don't go anywhere without my Leatherman. Pliers, wire cutters, knife , screwdrivers, church key, scissors, and more.
I've been carrying one, since they were invented, and worn out a half a dozen.
First aid kit.
7.5" Allen Mogul
The Mrs. wants her railroad around the house!
G. Augustus
Monte Rio, Ca.
G. Augustus
Monte Rio, Ca.
That’s a good one. I’ve gotten my hands on a fancy hand tapper in a tool room, and it’s been on the project list for a while to make one. I like yours better.gwrdriver wrote:A Tapping Stand.
I made mine from offcuts from various sources. The base was a dumpster remnant of 1" structural steel plate, working surface 8"x10". The column is 1.25" diameter steel, copper lapped to within a 10th over its length (my first go at lapping.) The arm is built-up from CRS, pinned and soft soldered together. Yes, soft soldered and its not gone anywhere. The ring at the top is a "clinch-collar" which works like a compression fitting and locks or unlocks the arm within a few degrees of turn.
The best thing about it, other than being made for little more than the price of the Jacobs #31BA 3/8" drill check, is that it reduced my tap breakage from some, to ZERO. I've found that it easily manages up to about 1/4" threads but above 1/4" the knob doesn't provide the leverage needed, but it will squarely start larger taps. In a couple of decades I haven't found the need to increase the leverage.
Hands down, the best thing I ever made for my shop.
My uncle was one of the designers of the World Trade Center and spent most of his career in the building. Literally from the ground up, as he was one of the engineers on the foundation.warmstrong1955 wrote: ↑Tue May 12, 2020 12:33 pmI don't go anywhere without my Leatherman. Pliers, wire cutters, knife , screwdrivers, church key, scissors, and more.
He was there for the 1993 bombing.
Several people from his office were on the elevator on their way to lunch when the bomb went off. The elevator stopped, the lights went out and smoke started coming in.
They pried the doors open only to be met by two 1" pieces of fiberglass-reinforced plasterboard.
Using their car keys, a nail file and a panel they removed from the wall, and with their backlit displays on their beepers for lights, they cut a hole in the wall and escaped into a bathroom.
For the rest of my uncles career, he carried two items with him:
A leatherman tool
A light stick (one of those ones you bend to activate).
He retired before the 2001 attacks, so luckily he wasn't there for that.
When he passed away, someone (I think my dad) stuck a swiss army knife and a small maglight in the casket.
Sounds strange even to me, but my most useful tools in the shop are the two electric garage door openers!
So simple to adjust Shop temperature, air movement, lighting, and access getting any of the 6 operating vehicles in and out!
One classic car, two motorcycles, one steam boat and two steam locomotives.
Loving the blessed life...
I have a small clamp on vice that I picked up from Harbor Freight for around $20. It is not something you can beat the snot out of and have it hold up for long but it is a pretty good vice for the price. What makes it nice is that it swivels in two directions. This is really useful for holding pieces for file work. It makes it easy to change positions for a better angle.
The other tool I’ll include is a couple of good files. It might take a bit of time but it is pretty amazing what you can make with just a drill press and some files.
I have an old old old 4"cresent wrench, i have never seen a 6" open up as far as this one. It's actually pretty tight still also.
Scotty Brooks
By the way Glenn, can I get my scissors back now?Glenn Brooks wrote: ↑Tue May 12, 2020 11:58 amSomehow I have three pairs of scissors in my toolbox, one in the garden shed. Four new pairs in the house. Wonder how that happened?
Scotty Brooks
Hahahahahaha. Absolutely.
Different strokes . . . and whatever gets the job done!
GWRdriver
Nashville TN
Nashville TN
Thanks. I'll send you the details if you're interested. I once had it drawn in Cad but it's missing from my dwg archive so it's probably sitting in an old hard drive, or it's gone. It will be short work to redraw it though.thunderskunk wrote: ↑Tue May 12, 2020 1:04 pmThat’s a good one. I’ve gotten my hands on a fancy hand tapper in a tool room, and it’s been on the project list for a while to make one. I like yours better.
GWRdriver
Nashville TN
Nashville TN
I have a 3" adjustable wrench that looks like a toy, but it's made better than any of my larger ones.
Comes in really handy.
- Greg_Lewis
See my avitar
Also, the three-cornered scraper is great for taking the sharp edges off most anything, even when spinning in the lathe. The tweezers retrieve any small screws from the parts department that are smaller than about #6, and the 4-inch Starrett rule is much handier than the more common 6-inch one as I can get it into small places if needed. Also it has graduations across the ends. I've had all of these for so long I don't remember where they came from.
And although not really low investment at about $100, my 6-inch disc, 1-inch wide band sander is perhaps my most used tool. Almost every part I make pays a visit to this little machine for deburring. And many parts that don't need to be to .001 can be profiled or whatever there; some parts are made entirely by sanding to size.
