Pulling a cold engine
Hello all, I keep hearing differnt stories. My question is where should the johnson lever be when towing a cold engine?
Thank you
Tom
Thank you
Tom
Re: Pulling a cold engine
I always will put the bar full corner in the direction being towed.
that said, if the cocks can be opened with out getting sucked closed. it should not make a difference.
Make sure your axle pump is in 100% bypass... Been there, done that. Got the "OMG!" when the guy towing the engine back to the bay started seeing water spurt out of the safety valves. "Ope... Let's open that bypass!"
self hydro i seeMike Walsh wrote: ↑Wed Jun 10, 2020 11:09 am Make sure your axle pump is in 100% bypass... Been there, done that. Got the "OMG!" when the guy towing the engine back to the bay started seeing water spurt out of the safety valves. "Ope... Let's open that bypass!"
OK, but if the JB is in the center are both ends of the cylinder connected to the exhust port?
No, all the ports should be covered if the Johnson bar is in the middle. Easiest way is like Cbrew said: Johnson bar in full gear in the direction it is being towed, axle pump off, brakes off, and cylinder cocks open if possible. Moving a dead steam engine presents a tremendous drag, so don't be surprised if it is still pretty hard to tow.
- PeterCraymer
Rod engines can be tough, but try to move a Shay by hand! That will wear you out if there is any significant distance to cover!
I try to keep the reverser in the direction of travel, cyl. cocks open etc. makes it much easier.
This post got me thinking........how do you keep the cylinders lubricated? Do you need to make any modifications to other lubrication points, or change what you are using as a lubricant?
Timmy
Timmy
illigitimi non carborundum
I must have a problem, no matter where I place the reversing lever the engine rolls very freely..no drag.
I have auto cocks, are they breathing?
as slimy as mine equipment is inside the cylinders, i can flat tow it a long ways before i have to worry about oil in the cylinderstimmy wheeler wrote: ↑Thu Jun 11, 2020 10:52 am This post got me thinking........how do you keep the cylinders lubricated? Do you need to make any modifications to other lubrication points, or change what you are using as a lubricant?
Timmy
