Patio's projects
- liveaboard
Re: Patio's projects
All that time to make a tool to fix an old flashlight, that's just crazy.
It's good to know I'm not alone.
Liveaboard, yeh, your not crazy either.
Here are a couple of screws I made for the stops on the tracer. I started with a 8mm class 10.9 grade bolt. It was not a fully threaded bolt. I cut the head off, spun it around in the collet, picked up the existing threads and cut the threads just longer than what was needed. Put the bolt in a collet block and made the flats with the same distance from the treads. Back the the lathe, and shortened both ends to proper length. Top one is new, bottom it original. The little divet, is from a wrong move, while picking up the threads.
This is the device it mounts in.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Forgive the past!
A while back, I bought a Hemingway, Mini Rotary Broach kit. It is capable of broaching an 8mm hex. The kit arrived, with the box split opened and material missing. I can say, the customer service at Hemingway is outstanding! They sent out the missing material, right away. I started to make the parts today. We will see how it goes.
Here are the first two finished parts. Lots of projects in motion right now! But it keeps me off the streets.
Forgive the past!
Forgive the past!
- neanderman
Impressive!
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
Neanderman, thanks!
Tonight progress. All the counter bores are done and the end is threaded 20mm X .5. The side facing out is not finished yet. It will get faced off once the inside parts are installed.
Forgive the past!
Forgive the past!
- liveaboard
20x.5; that's a really fine thread.
Nice looking work, as usual.
Did some painting this weekend, so I painted the Steady Rest, that I rebuilt to fit the Cazeneuve lathe. I used a little JB Weld to mold the bottom plate to the upper steady.
You can see that here.
https://www.youtube.com/watch?v=INcWJYFvSkQ
This is not a show job, more of a scuff and paint. It looks a lot better than before, and I am happy with it. Here is a picture.
Forgive the past!
Forgive the past!
Pat,
I am not sure they use JB Weld on the F15E Eagles but I like the video.
Seems the rain has driven us both back into the shop. Fall arrives in Washington.
Gregg
LOL oops! Thanks for the heads up on the bad link. It is kind of a neat video though.
I tried to link this one, so people could see where I had installed a new base onto the Steady rest.
viewtopic.php?f=24&t=89632&start=456
About midway down the page, is the proper place to look.
P
P
Forgive the past!
Forgive the past!
This is a "Hey Buddy!" job I finished.
I have a cousin in Arkansas that bought himself an old wood Jointer. The part that sets the angle for the fence had been repaired by a PO. The part did not survive the trip home. He has been a machinist for many years and is retired now. He does not have any desire to own metal working machines any more, but seems to be getting into wood working. A while back he offered me some tooling for free, and a bought a couple of tools he had for sale, also. He recently contacted me about making this for him, and we worked out a trade for one of the other tools he had for sale. I nice 8" Mititoyo digital caliper.
He really only need a very simple version of the part to make it work and I think that is all he was expecting. For me it was as much as a chance to learn by doing, on the rotary table. It took a bit to figure out the real dimensions of the part. A couple of conversations with Harold helped. It took me three times to get the part right. I messed up right off the bat when I was using the table saw to remove some extra material. The blade cut too far into the part. I went ahead and made the part anyway, using it to make sure my dimensions and set ups where going to work as planned. The second one, I messed up while orientating the part on the pallet. The third one was not perfect, but I figured it would work for him.
Here are some pictures from the process of making the part.
The drawing. Making of the pallet. So I could flip the part and machine the bottom side, without loosing locations. Pallet is made with it's locating pin at the center of the rotary table. This is actually the third and final part that is in this picture. This is the second part, sitting on the pallet, while doing some layout with a point in the mill spindle. I had trimmed off too much of the material for the part to fit anymore. Here I am using the failed first part to locate the material of the third part onto the pallet, making sure it is on properly this time. Go to next post to see the results!
Forgive the past!
Forgive the past!
Continued from above!
This is the final part, in it's rough in state. The mistakes that I made are more obvious here, than in the finished product. Here it is, all done, with the original for comparisons. My cousin says it worked perfectly. Here are a couple of pictures he sent me of it installed on the jointer. Still making a little progress on the rotary broach and bike projects, too.
Forgive the past!
Forgive the past!
- neanderman
Very nice!
Ed
Atlas 618
Atlas 618
