Flux Core fumes
Moderators: Harold_V, Scott
Kay_B
Re: Flux Core fumes
Post by Kay_B » Mon Mar 22, 2021 5:41 am
Yes, any technical vapors are harmful and it is best to work in a respirator if you do not work outdoors. In the room, a respirator is required, and until you ventilate the room, it is better not to take off the respirator.
liveaboard
Re: Flux Core fumes
Post by liveaboard » Mon Mar 22, 2021 6:28 pm
heislerboy wrote:
Fri Mar 19, 2021 3:57 pm
you can't use stick welding in a typhoon, the max wind speed to weld in is 5 miles per hour this is from AWS (American Weld Society)
Andrew
Welding in light wind works fine in practice, certainly more than 5mph.
However, when the wind gets really strong it will blow the ark right off the work.
I got no certification, but I did a lot of welding (a kilometer) out in the weather.
Russ Hanscom
Re: Flux Core fumes
Post by Russ Hanscom » Thu Mar 25, 2021 6:07 pm
Exterior welders use shields or shelters for wind protection. It does not take much wind, just a breeze, to cause unacceptable defects in stick welds. The x-ray man will tell you, and repairs are expensive.
