Help with journal springs?
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
PRR5406
Post by PRR5406 »
Folks, I need assistance buying journal springs. The equalizer plate has a ring cast so a 3/4" coil spring can sit in it. The spring needs to stand 1+3/8th's" tall. I'm thinking the coil steel should be about 1/8th" thick. I'll require 16 of these little boogers* to support a locomotive which I estimate at about 650 pounds overall. Less expensive would be a nice plus!
Is there a size number or code for properly locating such springs online? Can I simply plug those dimensions into a search?
*I love using tech terms!
Re: Help with journal springs?
Post by Bill Shields »
Lee spring has an excellent online calculator
cbrew
Post by cbrew »
PRR5406 wrote: Fri Nov 04, 2022 4:17 pm Folks, I need assistance buying journal springs. The equalizer plate has a ring cast so a 3/4" coil spring can sit in it. The spring needs to stand 1+3/8th's" tall. I'm thinking the coil steel should be about 1/8th" thick. I'll require 16 of these little boogers* to support a locomotive which I estimate at about 650 pounds overall. Less expensive would be a nice plus!
Mcmaster carr does have a good selection of springs,
I use die springs and based on the specs above.
these would fit the requirement
if 1.375 is a hard number, then using flat washers to shim for coupler height
https://www.mcmaster.com/9573K79/
PRR5406
Post by PRR5406 »
CBrew, thanks for the reference and numbers. I'm learning by the seat of my pants.
Glenn Brooks
Post by Glenn Brooks »
Die springs are a good choice for your application. Plenty of suppliers out there - do a Google search if you want better selection than McMasters car. Also the urethane?/synthetic materials springs are available - usually sold in solid rounds. These are better in some applications than die springs, and also can be had in traditional 1/8th inch coil shapes…. better living through technology!
