The main list just changed again, back to the single-level view.
Used to be at main I got an expanded view of all the forums and sub-forums, now suddenly I see just the main headings and have to click into and back out of each one individually. Some seem to have disappeared, also.
But I didn't have to log in, the cookies must still be OK.
Something change with the site?
OK, what happened?
Moderators: Harold_V, Marty_Escarcega
Re: OK, what happened?
no new posts in live steam forum since 4th ?
5 june 2004
Stuart
5 june 2004
Stuart
- Site Admin
Everything seems fine. I ran a test post and everything looks the same to me on this end.
Double check your preferences?
Marty
Marty
It's back to normal now, and I didn't change anything, either before or after the problem.
- Site Admin
Strange, thanks for the report back!
I'll have the website guru have a look see. Maybe HE was tinkering with it? B-)
- willjordan
I get the same sort of result anytime I lose the login -- must be bad cookies -- when this happens the first thing to do is to see if you are really logged in. If you are logged in, "Logout" is in your menu bar. If the menu bar has a "login" you are not really in as yourself and need to log in.
My broswer sometimes does a strange thing to me and drops my login; I just guess it's a Bill Gates special feature.
grace & peace
will
[url=http://willjordan.com]Will's Web Pages[/url]
will
