What type of belt?
Davisa
What type of belt?
Post by Davisa »
What type of belt for a vee to flat pulley? Totally confused.
Re: What type of belt?
Post by Bill Shields »
Neither
Charles T. McCullough
Post by Charles T. McCullough »
Replace one of the pulleys.
I actually have 9" a South bend lathe that has a V belt pulley on the motor and a flat belt pulley on the first intermediate shaft
It runs a V belt...but is VERY DODGEY and not much good for power transmission.
Since the next belt in the train is flat ..it really matters not
Had the lathe been mine, I would have changed the second pulley to a v belt.
Steggy
Post by Steggy »
Davisa wrote: Wed Sep 13, 2023 6:37 pmWhat type of belt for a vee to flat pulley? Totally confused.
As the others implied, you’ve got a putting-a-square-peg into-a-round-hole situation.  If you can, replace the flat sheave with a suitable V-sheave and use a V-belt.  Both items are readily available.  The much less-desirable alternative would be to replace the existing V-sheave with a flat one.
Music isn’t at all difficult.  All you gotta do is play the right notes at the right time.  :D
Russ Hanscom
Post by Russ Hanscom »
Depends on sheave sizes and load. I have a 1908 power hacksaw that was originally flat belt drive from a line shaft. Pulley is about 16"+ dia and 4" wide. It has been driven by a V belt for the last 50+ years. V pulley is 4"? Works great.
It is possible to have mixed sets, not optimum, but possible.
pat1027
Post by pat1027 »
https://www.bestorq.com/Library/TechInf ... Drives.pdf
A V-Flat drive. Never knew such a thing existed.
isn't that chart just helping with calculation of belt length?
John Evans
Post by John Evans »
Well a lot of South Bend lathes had a V groove pully on the motor and a flat sheeve on the countershaft. Seemed to work well enough on the 2 SB lathes that I had !
www.chaski.com
