G0678 CNC Conversion Build Log
This forum is dedicated to those Hobbyists Interested in CNC machining & 3D Printing in their home shops. (Digital Read Outs are also topical, as is CAD/CAM as it relates to CNC)
Re: G0678 CNC Conversion Build Log
Post by Bill Shields »
Ball screws are what they are. You must get past that hurdle, or there is little point.
Quill is a better choice for tool feed.
joedexter
Post by joedexter »
Gotta agree with that. So not wanting to reinvent the wheel here, has someone got specs and or a supplier previously used for ball screws for G0678? Random searches on internet are not fruitful.
My experience with these cases is that I have designed my own and had them made using standard ball screws / nuts -
companies take 'long lengths' of ball screw rod and machine the head / tail on them for you to order.
last set I ordered was from HiWin in Ohio. - no complaints or associations
they sell retrofit kits for many mills - XY table only.
joedexter
Post by joedexter »
Thanks Bill, I’ll follow up on this, eventually I’m responsible for my own errors…😬
Is real world attitude not shared by many these days.
joedexter
Post by joedexter »
Hiwin certainly are easy to deal with and willing to serve customers well.
Next step is stepper motors. I want dual shaft so I can manually control when desired. NEMA 34 1200 oz look about right. Starting to think about integrating the software drivers now. Linux or Mach4? (Here it comes….)
rrnut-2
Post by rrnut-2 »
Look at the Centroid Acorn, better support.
Jim B
joedexter
Post by joedexter »
G0678 CNC conversion
Anyone want to comment on carrier and thrust bearing for X axis. I plan on putting drive motor on right hand side and keeping LHS pretty much as OEM setup. Ball screw nut/holder as location as OEM.
Back to back angular balls on drive end.
Float on the other
Specific thrust not used
joedexter
Post by joedexter »
That makes it easier. Thanks Bill
joedexter
Post by joedexter »
I’m looking for ideas to fabricate a drive for the Z axis. Does anyone have pictures of how this might be done? I’m starting with the Z axis of the CNC conversion as it appears the be the most challenging.
