Bosch AB 33 magneto
This forum is for Internal Combustion Engines such as Hit 'n Miss, Throttle Goverened One Lungers etc. Repair, Machining, Operation, Buy/Sell/Trade of these engines are all topical.
Geochurchi
Bosch AB 33 magneto
Post by Geochurchi »
Good morning, anyone know anything about a Bosch AB33 magneto? I have taken it all apart, installed a new cap cleaned completely as it was submerged in saltwater, now only get a weak spark when using an inline spark plug tester, any thoughts?
Thanks
If it ain’t broken keep working on it until it is .
Geo 🇺🇸
Bob D.
Re: Bosch AB 33 magneto
Post by Bob D. »
If you took it apart and didn't have a keeper for the magnets they will probably have to be zapped. Failing winding insulation and bad condenser are also indicative of a weak spark.
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
Geochurchi
Is there a means of adding more magnets on top of the existing? I did use keepers when I removed the magnets, aside from a weak spark how can I tell if the magnets are strong enough?
Thanks
Geo 🇺🇸
Geochurchi
As an experiment could I use 2 fishing magnets 1 on each side to see if I get a good spark, if so I would get the original magnets recharged.
Just a thought.
Thanks
Geo 🇺🇸
