Anyone like shapers?
earlgo
Re: Anyone like shapers?
Post by earlgo »
Here is a very nice sized 8in Shape-Right shaper for the home shop. Really works well and is fun to watch, so the owner says.
--earlgo
Greg_Lewis
Post by Greg_Lewis »
earlgo wrote: Tue Mar 05, 2024 2:45 pm … is fun to watch, so the owner says.
That's something I enjoy. It's relaxing in this age of rush-rush.
Greg Lewis, Prop.
Post by Bill Shields »
but if you put a VFD on it, you can make it go faster.....
earlgo
Post by earlgo »
The Shape-Right indeed does have a VFD in the wall box at the upper left in the picture.
--earlgo
Greg_Lewis
Old proverb: "Make haste slowly."
Greg Lewis, Prop.
Bill Shields wrote: Tue Mar 05, 2024 7:57 pm but if you put a VFD on it, you can make it go faster.....
Chuckle!
I suspect you have something in mind, but speeding up a shaper, unless it was one built for carbon steel cutting tools, most likely wouldn't be a great idea thanks to surface speed requirements. Over speed when machining most metals would not be of advantage. On the other hand, if a guy machines a lot of aluminum or free cutting brass, yeah, it just might be a good idea.
I've not operated a shaper since I was a lad in high school. The only place I ever worked that had one was at Sperry, where I was trained. It was a big machine, a 24" Cincinnati if I recall, full hydraulic and located in the tool and die department. It sat unused better than 99.9% of the time.
Just seeing if anyone is paying attention.
My last 2 table top shapers went out 20 and 10 years ago respectively. Replaced my milling machines.
Never missed them.
.do smoke ix saddles as described by others here recently.
".do smoke ix saddles"
Translation please.
Greg_Lewis
Here's an old pic of how I did the smokebox saddle on the 7-inch Atlas shaper. You can see the angle plates and bits that I clamped to the shaper column to hold the saddle casting. It took some careful adjustments to get everything in the right place. The giant c-clamp on the shaper head is so I could use the "bonk" method to swivel the head a tiny bit after each stroke by bonking the end of the clamp screw with my fist. It all worked great.
25 copy.JPG (316.56 KiB) Viewed 715 times
Greg Lewis, Prop.
