Home built right angle head
JimGlass
Post by JimGlass » Sat Feb 12, 2005 12:05 pm
Made this right angle head for spot drilling from the inside diameter of a hard cast iron piece. The cast iron piece is part of an anti-theft device for semi trailers.
As you can see the drive shaft screws into the gear box with a special 1 1/8 - 20 thread. I made 2 spindles to hold drills. One spindle for 1/4 in shanks and another for 5/16 shanks.
Before doing serious drilling the gearbox will be covered. It worked better than expected.
Jim
www.outbackmachineshop.com
MikeG
Re: Home built right angle head
Post by MikeG » Sat Feb 12, 2005 5:10 pm
Jim
Beatiful work!
MikeG
In the shop; a Jet 8x36 vert mill, Jet 13x40 lathe. Harig 612 SG. Burke #4 HM. Van Norman #76 piston griinder
Patenteux47
Post by Patenteux47 » Sun Feb 13, 2005 12:31 am
Very impressive!!!!!
Post by Harold_V » Sun Feb 13, 2005 12:55 am
Very clever of you to use the mill spindle for alignment alone. A great idea well executed, Jim.
icemaker
Post by icemaker » Sun Feb 13, 2005 1:43 pm
Jim,
Another great example of the fine work you do. Not to mention the creativity involved in coming up with the concept in the first place. Very nice.
Bill
