Bead Roller
Moderators: Harold_V, GlennW
Russ Hanscom
Bead Roller
Post by Russ Hanscom » Thu Jan 12, 2017 12:17 pm
There were some edges on the FJ 40 floor pan that really called for a bead roller to get uniform contours. I checked the harbor fright offering and found it wanting, so off to the parts box. Other than $30 for the gears from Ebay it was all indigenous bits. The throat is adjustable in case a bit longer reach is ever needed. The rollers are easily changed so any profile I desire can be turned on the lathe then installed. Not a bad for a three day detour, now back to the floor pan.
warmstrong1955
Re: Bead Roller
Post by warmstrong1955 » Thu Jan 12, 2017 12:23 pm
Nice Russ!
A whole lot superior to the cheapies out there.
I bought one from Summit racing, very much similar to the Horror Freight model. A Woodward Fab thing.
The rollers didn't move apart with heavier steel sheet, they moved laterally. I welded on some angle stiffeners.
I should have built one like you did!
Re: Bead Roller
Post by GlennW » Thu Jan 12, 2017 12:50 pm
Nice work, Russ!
I looked at the imports and then stumbled onto a used Pexto with a box of dies and never looked back.
I supplemented it with a 6' length of 2 1/4" Stressproof and make whatever I need for dies.
Russ Hanscom
Re: Bead Roller
Post by Russ Hanscom » Thu Jan 12, 2017 5:02 pm
Finding a good used one was a thought, but there was nothing suitable at the time. I will make dies as needed. The bearings are aluminum with grease fittings so it will last.
Re: Bead Roller
Post by SteveM » Thu Jan 12, 2017 5:18 pm
Nice!
Re: Bead Roller
Post by BadDog » Thu Jan 12, 2017 6:25 pm
There are a lot of things in Glenn's shop that I covet... so just make that one more thing on the list...
I diddled around didn't pull the trigger quick enough on a 24" Pexto finger break a few years back, and kick myself frequently over that. But I've yet to find anything resembling a deal on a nice bead roller, or much of anything else with the Pexto name on it for that matter. Me, I've got an upgraded HF roller that gets the job done when needed.
Re: Bead Roller
Post by GlennW » Thu Jan 12, 2017 9:22 pm
A used sheet metal equipment dealer popped up less than a mile from me when I was in my old shop.
Prices were excellent, so I picked up a 10' Chicago Apron Brake and the bead roller.
Soon after that they closed up.
I wish I would have done a bit more shopping while I had the chance!
jscarmozza
Re: Bead Roller
Post by jscarmozza » Tue Dec 26, 2017 7:15 pm
I made a set of dies for my bead roller, one smooth and the other knurled in an attempt to simulate diamond plate on my 1" scale locomotive running boards....it almost worked. Since the shafts on my roller aren't parallel, I made the die diameters so they would be parallel when rolling 1/16" aluminum strip. Only problem is they aren't parallel, on 1-1/2" wide strip only half of the running board gets embossed. Do you think I should put a slight taper on one of the rollers to get an even pressure? Thanks,
John
