12" Guage Wheel Standard
Forum rules
rkcarguy
Re: 12" Guage Wheel Standard
Post by rkcarguy » Wed Sep 19, 2018 10:27 am
^^^ It probably cuts really nice. They make 1/4" round carbide inserts and holders, I've been watching ebay for one to come up.
My thought was to rough the wheels within about .030" and then finish cut them with that in one pass. Carbide likes to be "loaded".
dnevil
Post by dnevil » Fri May 03, 2019 10:05 am
I've created a first draft for a 12" Gauge Wheel Standard. Take a look.
http://ibls.org/files/Standards/IBLS%20 ... 0Gauge.pdf
This is based on the WF&P standard as published in Live Steam and Outdoor Railroading, Sep/Oct 2015.
I welcome feedback.
Daris Nevil
IBLS Secretary
North American Region
http://www.ibls.org
Glenn Brooks
Post by Glenn Brooks » Fri May 03, 2019 10:31 am
Daris,
Thanks for doing this. Hopefully others will comment also.
One question: should FW and WD be the same dimension? If not, how are they different? Seems like they should both be the same??
Thanks again,
dnevil
Post by dnevil » Fri May 03, 2019 10:38 am
Good question. If FW and WD were the same, then the flange would ride on the frog. You want the wheel flange to be shorter than the depth to the bottom of the frog.
Daris Nevil
IBLS Secretary
http://www.ibls.org
Glenn Brooks
Post by Glenn Brooks » Fri May 03, 2019 10:43 am
Daris, ok, understand now. One measurement is for the wheel, the other for the frog. Makes sense.
Thanks very much,
Mike Walsh
Post by Mike Walsh » Fri May 03, 2019 11:24 am
Perhaps a credit to the WF&P would be ideal. After all, the members of WF&P came up with this standard a long time ago.
dnevil
Post by dnevil » Fri May 03, 2019 2:40 pm
That's a good idea. I'll modify and repost. Thanks!
Daris Nevil
IBLS Secretary
http://www.ibls.org
dnevil
Post by dnevil » Fri May 03, 2019 2:46 pm
BTW, if you are viewing the PDF file in your web browser you will want to hold the shift key and click the reload icon to see the latest edit.
Daris Nevil
IBLS Secretary
http://www.ibls.org
rkcarguy
Post by rkcarguy » Mon May 06, 2019 10:22 am
The wheel gage WG looks a little big. Other than the flange depth and frog depth being deeper than I had planned on I'm looking good, and I have been using a 10mm bolt for spacing my guard rails (just under .400"). I'm modeling in 2" scale though, shouldn't hurt to leave my flange depth shallower on my wheels as long as my track is all to spec?
dnevil
Post by dnevil » Fri May 10, 2019 12:33 pm
rkcarguy,
Good catch, WG is a typo, should be 11.843 inches. I've posted an updated document.
Daris
Daris Nevil
IBLS Secretary
http://www.ibls.org
rkcarguy
Post by rkcarguy » Thu May 16, 2019 11:26 am
I'm surprised the flange depth is as deep as it is, but I guess that is based on 3" scale as well. Is there any rule of thumb for scale vs. flange depth?
I'm modeling in 2" scale.
Glenn Brooks
Post by Glenn Brooks » Thu May 16, 2019 1:24 pm
Ryan,
I’ve always heard that flange depth relates most closely to the profile of the rail and the frogs and points, etc the wheel must traverse, not the particular scale of the locomotive it fits on. ( In turn, size of rail, points, and frogs, determines carrying capacity and load stability - hence gauge, rail profile, and equivalent wheel design.) so your 2” scale locomotive would ideally be equipped with wheels that are most suitable for the 12” gauge track you wish to operate on. Prototype locomotive builders in the last century did this all the time, by progressively scaling engines and rolling stock to larger and larger sizes and carrying capacity, all the while maintaining standard gauge and wheel profiles.
Interestingly, In the earliest days of live steam development, Henry Greenly made a similar distinction between scale and gauge, and by reference - flange depth, saying that Scale determines the height, width of the locomotive, but gauge enabled the width of the selected fire box between the frame.
