Spindle Frequency?
Moderators: Harold_V, GlennW
dannys
Spindle Frequency?
Post by dannys » Fri Feb 15, 2019 5:54 pm
I bought and installed a new 1.5kw water-cooled spindle with an inverter to run it. Inverter is https://www.valinonline.com/products/esv152n02yxb . Now whenever I switch the spindle on it triggers my limit switches (in Mach3) and I can only reset it when the spindle is not running. Would adding a line reactor to the inverter help? Spindle and limit switch wiring is all shielded and properly grounded.
I'm virtually at a standstill. Any help?
Re: Spindle Frequency?
Post by John Hasler » Fri Feb 15, 2019 8:47 pm
We need to know more about your setup.
