Wacking the Morse taper out of the spindle
Moderators: Harold_V, GlennW
Mr Ron
Re: Wacking the Morse taper out of the spindle
Post by Mr Ron » Sat Jul 06, 2019 2:27 pm
shootnride wrote:
Fri Jul 05, 2019 7:23 pm
When I first got my lathe, the first time I had to remove the 5C adapter from the spindle I drove it out with a wood dowel. Like you, I was concerned about possible damage to the spindle bearings. Since then I have used a bearing splitter between the 5C adapter and the lathe spindle. Using this method the adapter comes out easily and doesn't put any undue stress on the bearings. I don't know if this method will work on your lathe or not, but it's some food for thought.
Ted
My Sheldon lathe uses a MT5/5C adapter with a push off collar. The collar is used to remove the adapter as it is threaded onto the threaded headstock spindle. I am missing the collar, so I have to wack the adapter out. So far, it doesn't seem to be doing any harm. The splitter sounds like a good idea. I will have to get one.
Mr.Ron from South Mississippi
Bill_Cook
Post by Bill_Cook » Sun Aug 04, 2019 6:34 pm
A morse taper is very slight and doesn't need to be drawn in very hard to hold.
BC
If there was only one way to do each machining job, the smell of sulphurized cutting oil smoke would have fewer fond memories.
Post by John Hasler » Sun Aug 04, 2019 9:35 pm
A Morse taper is a self-holding taper. One that fits well does not need to be drawn in very hard to need quite a bit of force to get out. That's why they have tangs and why Morse taper drill press spindles have slots for a drift to drive the drill bit out.
Mr Ron
Post by Mr Ron » Mon Aug 05, 2019 11:23 am
I ran a run out check with a DI and couldn't get a readout greater than .0005" in the x or y direction, so I think the bearings are OK. The lathe (and the bearings)are 75 years old.
