Wooden boxcar door track?
Moderators: Harold_V, WJH
DianneB
Post by DianneB » Fri May 03, 2019 1:23 pm
I am working on a 40 foot wooden boxcar (1/4" Birch ply) and haven't been able to figure out how to do the sliding door track. I'd really like to have the doors open-able. I have been searching the Net but not come up with anything.
Has anyone seen or come up with a way to make the tracks?
jeffsmith
Re: Wooden boxcar door track?
Post by jeffsmith » Fri May 03, 2019 4:32 pm
Wooden cars used several different methods but the most common was the use of a Z shaped track. Look at my web site and you'll get an idea how it works. branchlineproducts.com
The box car book has all of the information for the door operation.
Jeff Smith
DianneB
Post by DianneB » Thu May 09, 2019 6:12 am
Has anybody MADE working door tracks for a 1-1/2" scale boxcar? I have been scratching my head for weeks and haven't been able to figure out how to do it! :roll:
makinsmoke
Post by makinsmoke » Thu May 09, 2019 3:46 pm
Ha!
Nearly all of the cars with side doors on the C&IG had working doors when they were built.
Practical? Not for cars handled often.
Now, do you want doors that slide open and closed, or do you want that and them to look prototypical?
Brian
DianneB
Post by DianneB » Thu May 09, 2019 4:17 pm
I decided to just go with wooden slides for now (until I think of and build something better). Yes, I wanted working doors so I can store stuff inside or make fake cargo.
Roof finish next.....
makinsmoke
Post by makinsmoke » Thu May 09, 2019 4:47 pm
The easiest way to use that space for storage is a hinged roof. I’ve used piano hinges.
I’ll try and draw up a simple working door slide.
Brian
vernon911
Post by vernon911 » Fri May 10, 2019 2:49 pm
We have custom extruded Zee channel. 3/8"x3/8"x3/8" that can used for outside bracing and door tracks.
Price is $3/20" pc or $5/3ft. pc.
Sorry, its not up on our website yet. Note: the shipping isn't cheap so recommend ordering enough to do it only once.
info@precisionsteelcar.com
Sincerely
Paul
www.precisionsteelcar.com
makinsmoke
Post by makinsmoke » Fri May 10, 2019 9:22 pm
Omg, Paul can you use this for side bracing on single sheathed outside braced boxcars??
Rwilliams
Post by Rwilliams » Sun May 12, 2019 1:03 am
The sliding doors of many box cars and even passenger baggage cars were hung from above with what was called a door trolley on a railing. The bottom of the door was usually riding in a guide bar with perhaps what was called a slide to help stabilize the door during movement.
Most of the baggage car doors were inside hung but used the same basic hardware. Even when closed, the baggage car doors offered up plenty of air gaps and during cold weather were known for being very unpleasant for crew to ride in unless a stove was in use.
vernon911
Post by vernon911 » Thu May 16, 2019 9:02 pm
Yes, it works quite well for outside bracing. That is actually why we made it. Ray Grosser in KY has used for such and it turned out quite well. He has also used out roof ribs in flat form without the center peak for outside bracing of a different style. Very similar to a boxcar kit that Steve Morris used offer a long time ago. If you want feel free to contact me through the website and I can dig up some pictures. Someday we will get all our new parts up on the website but right now we are busy working on the limited run outside braced stock car kits and more importantly enjoying the kids spring soccer season.
Paul
