Wavy washers
toolroom
Wavy washers
Post by toolroom » Sun May 19, 2019 3:25 pm
I hope this question is in the correct forum, as I have an application to utilize a wavy washer. The posed question is: How does someone determine the tensile strength /compression value of a wavy washer. My 19th Edition machinery's Handbook says nothing about the wavy washers. Does anyone in the forums know how to calculate the compression value of wavy washers? Internet doesn't help much, unless I am searching in the wrong place.
Thanks in advance for any information.
Magicniner
Re: Wavy washers
Post by Magicniner » Sun May 19, 2019 3:56 pm
Ask a Manufacturer.
Re: Wavy washers
Post by GlennW » Sun May 19, 2019 4:18 pm
pete
Re: Wavy washers
Post by pete » Sun May 19, 2019 11:20 pm
You could also try a search for Belleville washers as well. I believe that's the more common industrial name.
Re: Wavy washers
Post by spro » Mon May 20, 2019 12:27 am
All we had to do was look a Glenn's links. A " wavy washer" is a set above regular shimming. If it is the right category and heat responsive, it can do what flat shims can't.
toolroom
Re: Wavy washers
Post by toolroom » Mon May 20, 2019 9:32 am
Wow, Thanks for all the information. I printed the page out for future references. I appreciate the help. Thanks again!
Re: Wavy washers
Post by John Hasler » Mon May 20, 2019 9:38 am
No, wave washers are different. Belleville washers are sort of dome-shaped and flatten out under pressure. They typically have quite a high spring constant. Wave washers are "wavy": alternating high and low areas. They have lower spring constants.
Belleville washers: https://en.wikipedia.org/wiki/Belleville_washer
Wave washers: https://en.wikipedia.org/wiki/Washer_(h ... ng_washers
pete
Re: Wavy washers
Post by pete » Mon May 20, 2019 7:55 pm
Thanks for the clarification John. As usual there's always more to learn.
