Gluvit
Glenn Brooks
Gluvit
Post by Glenn Brooks » Sat Jul 20, 2019 9:53 pm
Anyone have a recommendation on the use of Gluvit to repair a leaky tender?
My 1950 vintage tender started leaking around the outlet recently. I found the builder used some sort of seal coat inside the galvanized riveted tank. The innner sealer finally failed and started flaking off, hence the leak.
I’ve since replaced the outlet plate and welded in some new sheet metal to replace a bit of rotted sheet metal, near the leak. However the heat of welding has opened up two small leaks around the front edge of the tank. Iam thinking of mixing up a bead of gluvit to paint around the inside bottom seal (about 12” linear inches) in hopes of saturating the area of the leak.
Just wondering if anyone has used this stuff and what your experiences are?
Fred_V
Re: Gluvit
Post by Fred_V » Sun Jul 21, 2019 6:55 am
I have used gas tank sealer with good success.
Fred V
Pensacola, Fl.
Re: Gluvit
Post by Bill Shields » Sun Jul 21, 2019 9:48 am
I like PQR sealants and / or Devcon rubber (mix up a batch, paint it on fast and throw away brush).
Greg_Lewis
Re: Gluvit
Post by Greg_Lewis » Mon Jul 22, 2019 1:36 am
The issue of tank sealing comes up here from time to time and folks have all sorts of solutions. IMHO, the best solution is to use a tank sealant like what the antique auto restorers use. Since it's made for sealing tanks, it should work. All the other solutions seem to me to be shots in the dark. I used the KBS Gold Standard Tank Sealer, but you must also prep the tank properly. I bought their complete kit which includes the cleaner.
