mini V12 I.C. engine
Moderators: JackF, Harold_V
breadf
Post by breadf »
I designed this engine. It's a single cam engine. below is the specs:
Dimension: 208 (L) x 112 (W) x 159 (H) mm
Type: Single Over Head Cam, 24 Valves
Stroke: 18mm
Bore: 16.68mm
Displacement: 49.89CC
Fuel: Petrol ( no oil mixture)
Cooling: Water Cooling & Dry Sleeve, Gear Water Pump driven through sync belt
Oiling: Splash Oiling
Start: 480 Brushed Motor Starter
One Piece Alloy Steel Forged Crankshaft and Camshaft, 7 x Bearings Support
Japanese bearings for Crankshaft, Camshaft and Gear Pump
Single Piston Ring in Taper Face & Ductile Iron
Big Dint Carb & Air Filter Cover
Total 6 x Crankcase Breakers, 3 at each side
CDI is automatic advancing angle ignition type
how do you like it? I am sampling it yet. maybe the end of month I could get it to boom.
https://youtu.be/GeI-UmzUjLk
