SPOKEN FOR OK back when labor was cheaper than parts AMMCO made brake cylinder grinders to clean up the bores of automotive hyd.brake cylinders. 30s-50s era you could buy oversize wheel and M/C kits ,like .010 over or so.
What I have here is 3 sets that cover from about 7/8 to 2-1/2 depending on stone ware. The sets have # 0-1- 2 of# 2 and #350 bodies .The stone carrier's are all interchangeable between bodies. The other long item uses emery cloth covered carriers ,designed to fit piston pin bushings and pistons for O/S or replace bushings one off in the car chassis ! Anyway it's size is just under 3/4 to about 1-1/4.
I mostly used these to fit sector shaft bushing in car steering boxes, run wet under parts washer flow with a cordless drill worked a treat.
Now the $$ ! $175 shipped for all of it. Not as good as having a SUNNEN but a lot better than anything else.
PS you can use the 1/4 Sq. abrasive stones to replace worn out stones on the carriers ,just glue on. You L/S guys could use these for cleaning up/better finish on your cylinder,after all W/C were C/I.
AMMCO Cylinder Grinder/Hone sets Offers? ****SOLD****
