Needed - Atlas 12" Lathe Tailstock Quill / Ram / Barrel / Spindle
Buying, selling, trading and for giving away Items of interest to the Home Machinist Community. (Non-Commercial Only) *PLEASE BE SURE TO LIST CONTACT INFORMATION AND LOCATION OF ITEM*
rsterne
Re: Needed - Atlas 12" Lathe Tailstock Quill / Ram / Barrel / Spindle
Post by rsterne »
It was in good shape, and removing the handle is how you get it out.... already did that....
Bob
Post by Bill Shields »
Duh :mrgreen:
rsterne
Post by rsterne »
I repaired my lathe today.... Bored out the quill and inserted a new Acme threaded brass bushing with Loctite 638.... It turns out that the difficulty I had drilling those Metric bolts was partly the threads in the process of stripping.... The repaired lathe drilled them no problem, with HSS drill bits.... ::)
Thank you to all here for your advice, much appreciated.... 8)
Bob
Post by SteveM »
Bronze is one of the few metals that works well sliding against other metals (cast iron is another one).
Joe Nelson's "So you want to build a steam locomotive" had a great chart showing which metals against which metals were bad to good. Worst was probably aluminum on aluminum.
Bronze was good with everything, IIRC.
rmac
Post by rmac »
Look here for a similar chart (and lots of other related info, too) if you don't happen to have that book.
-- Russell Mac
Post by SteveM »
rmac wrote: Fri Feb 17, 2023 9:41 am Look here for a similar chart (and lots of other related info, too) if you don't happen to have that book.
That's useful, but I think that Nelson's chart took into account that some materials were bad because they galled.
I think I need to make my next pistons out of diamond :-)
