Propane Burner options
Re: Propane Burner options
Chris,
Is there any design information available for Von Ruben burners?
GWRdriver
Nashville TN
Nashville TN
Chris:
Al Von Rude told me he made a burner for "a Challenger in BC, Canada."
Now we see it.
I have one of his outstanding burners in my Mikado, with a small pilot light sticking up between two burner tubes just inside the fire door.
Works like a charm.
Now we see it.
Works like a charm.
Some is available, even in Al's hand writing.
- Attachments
- 0-4-0 burner Al's.pdf
- (41.62 KiB) Downloaded 145 times
- Al VonRueden's Orifice Mixing Head.pdf
- (36.38 KiB) Downloaded 128 times
- Orifice sizing for propane.pdf
- (108.99 KiB) Downloaded 127 times
- Propane Burner Calculation Notes from Al VonRueden.pdf
- (27.23 KiB) Downloaded 125 times
- Burner 1 small.jpg (158.29 KiB) Viewed 1998 times
ABAB
atta big a** burner
atta big a** burner
Big Burner, yes. And easily controlled.
That Challenger burner can easily heat a garage!
Chris:
I discovered that my burner, which burned nicely blue on the table, required additional air into the mixing tube once enclosed in the firebox, even with the bottom open. Pic attached showing the yellow flames, indicative on incomplete combustion.
It burns blue after the air input adjustment.
Chris:
- Chris Hollands
Thanks for the heads up Russ .
The Challenger burner was the largest Al designed at 24" long by 12" wide some 1200 holes and he was heating his workshop for about 2-3 weeks before he shipped it to Australia . Ive had it now 22 years and this is the first time I have fired it ready to install properly .
The Challenger has taken a little longer than I thought - now at 16000 hrs and 26 years hopefully will be running later this year if life does not get in the way .
Chris:
I hope you get it running this year. It obviously has been a HUGE project for you.
Wishing you the best, and looking forward to seeing it steaming and moving on rails!
I also built a tube style burner, but based off the write up from By Lindsay McDonnell.
the recovery on the test stand was impressive.
- Attachments
- 20220219_150144.jpg (171.16 KiB) Viewed 1824 times
- 20220219_150151.jpg (239.14 KiB) Viewed 1824 times
- 20220220_124830.jpg (327.45 KiB) Viewed 1824 times
- 20220507_105001.jpg (447.03 KiB) Viewed 1824 times
- Chris Hollands
The only difference between Al's burner and Lindsay's design and I maybe wrong is the pressure they operated at .
Al's was low pressure 1-3psi and Lindsay's was higher pressure up to 20 psi .
Al preferred things a bit quieter .
that maybe true,, I didnt follow the design that closely,
I built mine using about 50 dollars of material and used a 1/16" clippard barbed fitting for the jet
at low frame where i just had frame across the whole burner, the needle didnt lift off the peg,
the attached image was at max just before the frame tips started turning color,,
all in all, very impressed and happy with the burner
- Attachments
- 20220220_093436.jpg (248.07 KiB) Viewed 1747 times
- 20220220_093444.jpg (283.46 KiB) Viewed 1747 times
Well done, Chris.
