One of the things that I've found in the toolbox that I purchased are three arbors.
An R8-JT33, R8x3 and R8x4.
I get the R8-JT33 is probably for a drill chuck.
But what would the R8x3 and R8x4 be used with?
Question about R8 arbors
Re: Question about R8 arbors
The R8-3 and R8-4 are probably for drill chucks too.
What does the 3 or 4 denote?
I wouldn't think Jacobs because I didn't think there was a JT4.
What do the x3 and x4 look like? Can you post a picture of them? If not, can you describe them? Do they have the same shape and proportions as the JT33 one? Are they tapered or parallel?
As requested. JT33 on the left, R8x4 in the center and the R8x3 on the right.
This is what Jacobs lists for R8 shanks -VelocityDuck wrote: ↑Mon May 15, 2023 2:01 pm What does the 3 or 4 denote?
http://www.jacobschuck.com/arbor/54.html
The some import chuck adapters seem to drop the JT when they label the arbors.
Those measurements match up to the 3 and 4 arbors. I hadn't heard of the Jacobs 4 before.
Thanks for the assist!
