Several years ago I found a control circuit for a locomotive drive using a gasoline motor to drive an automotive
alternator which in turn powered dc motors to the wheels.
This was linked to an Australian site I think called SMEX which I can not find.
The individual that developed this was using this system on small switcher engines on an
1 1/2 railroad.
Any Help Appreciated on the link or the circuit .
Gasoline electric drive circuit
Re: Gasoline electric drive circuit
Here’s the link I have for the site. Unfortunately, it appears the site is down with errors, so it can’t be loaded, at least in my browser.JohnR wrote: ↑Sat May 20, 2023 12:11 pm Several years ago I found a control circuit for a locomotive drive using a gasoline motor to drive an automotive
1 1/2 railroad.
The circuit described at the above site is not complicated—basically adjustable resistance exciting the alternator. As I recall, there seemed to be a lot of trial-and-error involved.
The site is archived on the Wayback Machine. This link works for me.Steggy wrote: Unfortunately, it appears the site is down with errors, so it can?t be loaded, at least in my browser.
Yep! That’s the one.
- Erskine Tramway
Colin Edmondson in England uses that drive method on his locomotives. it works fine.
Mike
Mike
Thank you
