Aluminium wheels
Muskymoto
Aluminium wheels
Post by Muskymoto » Sun Jun 06, 2010 11:01 am
Me and my dad do abit of casting and are abit short of aluminium
And have found a source of aluminium car wheels
do they contain anything else like magnesium or anythnig that will stop us using them?
Cheers
Thanks in advance
Marcus
steamin10
Re: Aluminium wheels
Post by steamin10 » Mon Jun 07, 2010 11:30 am
Generally speaking no, the are fairly consistant with alloy content. They are of stronger grades of aluminum without zinc additions that cause oxide and strength problems.
A simple swipe with a grinder will generate long spark streams, if it is magnesium. Magnesium cannot be hadled in a common casting furnace, as it readily ignites, and cannot be extinguished with water, it must be smothered in oxygen preventing material, like sand.
Falcon67
Post by Falcon67 » Mon Jun 07, 2010 3:37 pm
Besides, if you run across any old school drag race/performance real live magnesium wheels (like from the 60s), they are worth huge bucks if still intact.
Chris -
http://raceabilene.com/kelly/hotrod
"Check all parts for proper condition before operation; if normal safety precautions are noticed carefully, this machine can provide you withstanding of accurate service."
Muskymoto
Post by Muskymoto » Tue Jun 08, 2010 11:58 am
Ok cheers unfortunatley there not old ones there rather new ish
would you guys use them i still have to swipe one with a ginder to find out but could they contain much else?
Cheers for help
Marcus
tomc
Post by tomc » Tue Jun 08, 2010 9:21 pm
Marcus,
Aluminum wheels make a good source of aluminum for casting. Break it up and melt away. Depending on the make, there should be very little steel to worry about. I don't think they mixed aluminum and magnesium so you should be safe. IIRC, vinagar on magnesium is the test. Can't remember the outcome anymore. Maybe Google can tell you if no one else can chime in. I now if I could get my hands on some bent wheels, i would melt them for our foundry.
Tom C.
tom_at_srclry_com
Lost somewhere in Michigan!
Post by Harold_V » Tue Jun 08, 2010 10:16 pm
tomc wrote: I don't think they mixed aluminum and magnesium so you should be safe.
Safe is correct, but many of the aluminum alloys contain low percentages of magnesium. The highest I found (5182) was 5%, but most are below 2%.
Vinegar (acetic acid) will dissolve magnesium, but not aluminum.
steamin10
Post by steamin10 » Wed Jun 09, 2010 10:46 am
The only thing I worry about is using any pot metal, that is really not aluminum, but mostly Zinc. It is weak and creates really large crystal structure in heavy cross sections. It can be handy by itself for detail parts that dont require a lot of strength. (Also referred to as Diecast, it has been largly repaced by various forms of plastics in automotive uses)
Remember to keep any steel or iron away from your molten aluminum, no screws or bits of rivets in the melt. It will have negative effects on your casting.
