One-off shaft for a gearbox
This forum is for those individuals or small business to solicit requests for Service from those members of our group. Machining, Foundry work, Sheet Metal work etc. This site makes no guarranty of work or represenation by the users of this site. It merely attempts to provide a place to allow individuals the opportunity to meet and discuss needs and capabilities.
caddais
Post by caddais » Wed Aug 25, 2010 8:07 pm
Looking for quotes for a single shaft in a gearbox.
The shaft is from a gearbox in an older John Deere 24 skidsteer I am rebuilding.
I normally do most of my own shafts, but I don't have the tooling or experience to do the internal keyways required for this shaft.
I attached a JPG drawing of the shaft, if you want a clearer drawing let me know I can send a dxf file.
Let me know of any questions.
Don Lawrence
Gearbox shaft
Re: One-off shaft for a gearbox
Post by Harold_V » Wed Aug 25, 2010 11:15 pm
Don,
If you're comfortable making your own parts, the internal keyway isn't all that hard to make, assuming you have a drop spindle mill (a vertical, such as a Bridgeport). You can stroke the keyway easily using the quill and hand ground tool.
steamin10
Post by steamin10 » Fri Aug 27, 2010 12:00 pm
I have done such keyways by using the carriage on a lathe after putting the part on center, at the 3o'clock position in the chuck. On my SB lathe the head is locked by engaging both high drive, and the back gear. Wth a bit cut for the boring bar and aligned for center, repeated draw cuts with the carriage by hand gives me the results I need. Just dont be hoggy on the cross feed and measure well.
