New cab and controls for the SR&CL Ry #10
For discussions that drift from original topic.
An informal area for conversations, humor and observations that aren't necessarily strictly railroad related. No discussion of politics or religion. Ads are not permitted.
tom c
Conductor
Postby tom c » Wed Jul 14, 2010 10:52 am
Hi all,
I thought if the moderator doesn't object, i would put some building pics in here of our 3 3/4 inch steamer. The owner (Jack) wanted a more scale appearing cab and our builder (Mel) undertook the challange. Here is the pic of the start. The cab makes it look like a phone booth on a boiler. More to come?
Tom C.
tom_at_srclry_com
Lost somewhere in Michigan instead of Colorado!
Mark D
Conductor
Re: New cab and controls for the SR&CL Ry #10
Postby Mark D » Wed Jul 14, 2010 11:45 am
I think it's "cute." Sort of looks like a childrens storybook engine. Cool.
Mark D.
tom c
Conductor
Postby tom c » Thu Jul 15, 2010 11:54 am
We welded up a new frame,
Tom C.
3 New cab for SR&CL Ry #10 12-30-09.JPG (27.13 KiB) Viewed 5920 times
tom_at_srclry_com
tom c
Conductor
Postby tom c » Thu Jul 15, 2010 11:59 am
Added the roof and some paint, then placed on engine for fit and to size up the water tank & coal bunker.
Tom C.
3-#10 new cab frame 01-18-10.JPG (25.12 KiB) Viewed 5920 times
tom_at_srclry_com
tom c
Conductor
Postby tom c » Thu Jul 15, 2010 4:47 pm
Next up was puting the new front and sides on
#10 new cab frnt 01-29-10.JPG (36.66 KiB) Viewed 5918 times
Then placing back on frame and checking the clearances and adjusting as necessary.
Tom C.
#10 new cab side view 01-29-10.JPG (35.49 KiB) Viewed 5918 times
Junk_Man999
Conductor
Postby Junk_Man999 » Sat Jul 17, 2010 5:18 pm
Quite an interesting little project. What kind of whistle is that on there? I think it's a Buckeye 3 chime, but I may be wrong. It just looks about the right size.
All Aboard!!!
tom c
Conductor
Postby tom c » Mon Jul 19, 2010 8:47 pm
The whistle is home built from plans in Live Steam Magazine.. It is close to what was on B&SR #7 as that is what the article was about.
Tom C.
tom_at_srclry_com
tom c
Conductor
Postby tom c » Tue Jul 20, 2010 9:11 pm
We moved the Johnson bar back to shorten the reach for it and had to lenghten the reach rod, moved the cyclinder cock drain lever back and had to make a jog in it to go around the injector line.
A shot of the left side injector and some of the air pump.
Tom C.
tom c
Conductor
Postby tom c » Tue Jul 20, 2010 9:14 pm
Another task was to add air cooler lines to the air system.
Tom C.
tom c
Conductor
Postby tom c » Tue Jul 20, 2010 9:21 pm
Another task was to put in levers to control the water valves to the injectors. The valves are mounted to the frame and the plumbing waits for the tank to come back from the fabricator. The air brake line was mounted to the frame and hooked to the truck in the top photo.
Tom C.
tom c
Conductor
Postby tom c » Thu Jul 22, 2010 8:49 pm
Some shots of the cab interior. The copper lines in the front of the cab are for the air sanders. They are controlled by the blue lever in the top left of the cab. The air brake lever is on the left also. The big black resevoir in the cab left front is for the sanders. It holds a shot for the first big puff. The big ring is for the whistle. On the side of the cab by the door window is the water vavle handles.
Tom C.
4-Inside cab #10 lt side 06-26-10.JPG (36.32 KiB) Viewed 5890 times
tom c
Conductor
Postby tom c » Tue Jul 27, 2010 4:01 pm
OK, enough of the construction shots, the finished cab and painted engine!
Tom C.
tom_at_srclry_com
Return to “Roundhouse discussions”
Who is online
Users browsing this forum: No registered users and 1 guest
